Hi solar crowd,
I have a question regarding a planned setup of panels that would require the use of optimizers but given their price tag, I am wondering if I could do wire mutiple panels on a string into a single optimizer?
The reason for this is:
I have a south facing roof space and an east facing roof space. The big south facing roof has a top row of 5x 465W Panels and a bottom row of 5x 545W, the east facing roof has a another 4x 465W panels which are currently wired into one string going into MPPT1 of my Solis Hybrid Inverter (6kW).
The 5x 545W panels are wired into a flat roof system located on my garage, which are positioned towards due south at the same angle as the roof mounted panels.
If you haven't guessed it already, as soon as the sun moves towards south west, and then west, 4 out of the 9x 465W panels are sitting in the shade and my overall string performance ein MPPT1 drops significantly as I did not use any optimisers.
Now to my question: Would I need to add optimisers in between each of those panels on that string, or could I simply put one optimizer in between the south facing (5 panels)
and east facing (4 panels) facing array?
Thanks a million in advance,
Hendrik
Hendrik
