Bear22
- Dec 13, 2022
- 37
Guys,
Looking for some input on sub panel configuration. I have a sub panel installed by a certified Enphase installer. Equipment-wise, what's the possibility (if any) of a sub panel that can be manually switched (and isolated) from one battery backup system to another? Currently, I have an Enphase battery , but wanted to explore the possibility of having a DIY battery system ran through the same sub panel.
Do any of the commercial manufacturers make such a sub panel with some kind of a manual switch feature between two or more power sources?
Thanks Much!
G
P.S. Assuming this isn't feasible; what about the possibility of running the DIY battery through an Enphase installed gas generator plug in?
Thanks Much!
G
