spottiedog
I have 4 -100 watt panels going into a combiner box with a 50 ft. run to the Equipment. The charge controller is connected to the 2-24 Lifepro volt batteries and a 3000 watt inverter. The charge controller is showing about 21-23 volts going in but the indicator shows it;s not charging it's in stop mode not charge mode. Now my green charging indicator light did come on for a minute and the charge indicator showed fast charge but the went back to stop. My batteries are going down now to about 21 volts.
Also when I turn on the inverter it activates for about 10 seconds but the beeps and shuts down .
Could it be my batteries are too low now ? Or my run from the panels to the equipment is too far/
