The 12 pin connector is a can bus connection. 2 pins are 24V for the fan, the rest are unknown, completely. Several have tried to figure it out, some have read data, but as for "control" sorry, nobody has cracked that nut.Does anyone know if these units have header for CAN bus communication off them? Victron indicates that they support some BYD units for direct monitoring.
very interesting.So I bought one of the TechDirect BYD BMS units. I see it show up on Bluetooth. Anyone have a link to the App/Software for it?
(I emailed TechDirect but no response and none of my searches turn up anything.)
Does anyone know why the BMS wouldn't reconnect? I have a friend with 5 of these wheeled units and the voltages dropped down low enough the disconnect via the BMS. Only one turned back on when 24v was applied to the load side. How do I get the rest to reconnect?
When I read about you getting a bluetooth signal I tested my units - no discernible pairing signal on my phone or iPad. Of course the BMS is buried in a metal case on my pre-assembled units... details about your matching protocol? ID? Pairing device?
I am charging one of these now and my charger is set to charge to 29.2 volts. I am currently seeing 29.21 and still charging at 8.52 amps constant voltage. The current continues to go down. I will update when current drops to zero. I bought my BYD 24 volt 220 Ah batteries and the BMS you are referring to here as stand alone items and wired them myself. I have 8 of each and because of health issues I can no longer seek my goals of solar independence from grid. All the batteries and BMS’s are for sale. BTW I am still charging at 7.5 amps.Official response from TechDirect:
So anyone know of another decent 8S LFP BMS that will handle low temp cutoff, handle 150A & preferrably have a screen? I know there's the Chargery and I've built one pack from 180AH prismatic cells for another project. Was hoping for something like the DALY or ANT versions, but with low temp cutoff.
In addition, I am capacity testing @ 0.05C because I have only a 3 ohm resistor @ 1000 watts for that use.I am charging one of these now and my charger is set to charge to 29.2 volts. I am currently seeing 29.21 and still charging at 8.52 amps constant voltage. The current continues to go down. I will update when current drops to zero. I bought my BYD 24 volt 220 Ah batteries and the BMS you are referring to here as stand alone items and wired them myself. I have 8 of each and because of health issues I can no longer seek my goals of solar independence from grid. All the batteries and BMS’s are for sale. BTW I am still charging at 7.5 amps.
Big Battery recently broke up with their manufacturer (Battery EVO) The specs big battery were using seem to be inflated from the actual manufacturers specs on the same batteries they also sell under thier own brand... They even recommend and sell the wrong voltage charger (58.8v) to go with the 16s lifepo4 packs they sell..TechDirectClub.com sells them for $150 - spec at their website. They come installed in the pre-built units that are now sold at BigBattery.com. As far as I can tell, there is no way to interface, program or read information from the BMS - hence my question about the translation.
