Testing current draw on a 12v 100ah battery
rloveless
Utah
I'm going to be testing a few different 100ah batteries....Specifically, I'd like to test that they can support a constant discharge of 100 amps. I could hook up a large inverter and plug in a few loads but I was wondering if there is a better way. I could use one of these but it only goes up to 20amps. It would be nice if there was something out there that could be adjusted between 20a and 150 amps. I'd appreciate any thoughts or ideas.
Thanks
The issue is you have to dissipate ~1280W of power to pull 100A.
This would get you close:
10x 12V 100W halogen bulbs:
10X holders:
It could be variable by inserting/removing (after they cool) bulbs for 100W increments.
ah.. I like that idea. I can't believe they're advertising those for regular house use. Wow!
Thanks
After I repaired the loose B+ terminals on my BB10012s, I charged each one until at 14.4vdc, the amp draw was nil.
Then I connected a Renogy 12v 3kw inverter with a cheap (but it works) Hall coulombmeter and drained each one until the inverter shut down.
I used a home-made dehydrator that has two 100w bulbs and a 3 amp fan one top of a stainless steel gas grill housing.
Worked well, as I was able to see a constant 16-18adc draw for almost 6 hours. Made me confident I'd saved three $1k batteries.
Please, everyone bear notice here. I bought these BB10012s, eight here in my house and six in the rental. My system is 48v and the rental is 24v.
The six in the rental were abused, like a beaten dog.
I have yet to need to run the generator here at my house. I spent the other day cutting 2" square tubing and WELDING with an old Harbor Freight flux/wire feed welder.
Folks....................I NEVER needed the generator to supplement power. Presently it's pitch-black out and the voltage is 53.7vdc.
Thank you! You guys are great. I just ordered some. Just curious, How do you know that it won't melt when I connect the wires to the terminals?
Thanks again.
You don't necessarily. You might be able to find a max ampacity for a given product. They have a very high melting point, so spreading it across multiple strands helps.
This color chart helps:
and if you can blow a fan across them, that helps too.
I've done this for similar purposes years ago, and it was trial and error.
Very cool. It should be a fun experiment anyways.. 73. Thanks.
Couldn't you use a DC water heater and a controller to adjust the power? I used to make moonshine and used AC heaters with a custom controller to control the exact power so I'd get the perfect setting. Although might have been pwm so maybe wouldn't work.
I just did this yesterday (check my post) and used my inverter with rooftop AC units to confirm my battery could pull over 100a each
