Made in China = Dritte Welt Support.I got feedback from daly. Daly will not support us direct.
Only the direct buyers.
No Firmware Versions, no Support, no Informations!
It's a sham.
I have exactly the same issue, so it’s not just you. I can’t be sure but it might be since I updated to iOS 16.2.
I came to this thread to see if there’s a solution, but I tend to think that when an iOS update breaks an app, it’s normally just a matter of time until there’s an app update which fixes it, so if I need to just wait a while I can survive without bluetooth remote telemetry from my Daly. Especially this time of year.
Thanks for the info and the tip, I’ll check that other thread outI'm still running on iOS 15.7. I haven't updated to 16.x . Things stop to work when I updated smart-Bms to 2.0.1.
So not related to iOS.
I have found this other thread , maybe a solution for us too :
Daly BMS connected Bluetooth but no data
Hi all. My Daly 250 BMS has been working fine for 2 years (and still is working fine I think). But now when I connect to the Bluetooth it connects but I get a screen with no data. Any suggestions? First noticed it today. Last checked it all a week ago and it was fine. Trouble shooting so...diysolarforum.com
Ja. Läuft ok.Hat hier jemand schon auf die neuste Android AppVersion 2.5.2 aktualisiert?
If your BMS has not stopped and you have sensible values in a working App, DO NOT update the firmware!Not sure which security code to use to update this version. Just 123456 or one of the other firmware related codes named in this topic. Using android app version 2.5.2
Software version. 20210729-1002A
Daly 4s 150A 12V
Could this firmware be good for this?Today I got a new firmware from Daly. It seems to solve the current problem. May someone else tested it? It is only for Hardware St103-309 and named Inverter Basic Version.
Can you clarify what you mean byI had this issue and now it is resolved.
First of all if your BMS seems to not boot anymore. don't worry connect it to the PCS (still you will not see the battery stats) its normal.
1- try different firmware. i had to try like 4 different firmware from Daly before it was successfully updated/upgraded.
2-dont worry about the Firmware code. that's going to be displayed if you connect your BMS via Bluetooth while it failed the firmware upgrade/update.
3- be patient. even Daly support seemed they didn't know what they were asking sometimes.
even though my BMS works now i have replaced it to JBD.
good luck
