Fluff34567
Hello all,
Newbie after some basic advice...... long story to explain it all- sorry.
I'm located in central Europe and had an idea to buy some used solar panels and a battery to power a string of LED lights to light up the garden.
I have the lights its a 30m string of 4w LED bulbs total of 60 bulbs / 240w, i could reduce it down to 120w , I haven't measured the actual power draw but I'm a bit sceptical about the 4w as they are a bit dim.. measurement at a later stage!
After the initial rush of excitement and after picking up 2 used 265w panels I realised to power a 240w or even 120w load for about 6-8 hours will take a huge stack of lead acid batteries or a large lipo battery that will cost a fortune.
The lights are 220v so I need an inverter as well.
I have 2 options as I see it.
Get some class B lipo batteries and build a pack myself - still expensive.
What capacity would I need 280ah??
Option 2:
Forget the lights being powered by solar and use the 2 panels to supplement my house power.
In Europe " balcony solar kits" are popular. The panels are normally connected to a combined micro inverter/ charge controller and the 220v from the inverter is simply plugged into a house electric socket.
The idea is any power from the panels will be used up by any running appliances in the house and supplement to normal mains power supply.
My question is has anyone done this as a DIY kit using separate components ? I haven't seen the specs or a brand none of an all in unit yet.
Sorry for the rambling on!
Thanks for any help in advance.
Option 2:
