Hi everyone,
I’m finally ready to ask my scary grounding question(s). I’m confused on the most effective and safe way to do this. The overarching theme is that we have some land with nothing on it, and we want to power 2-3 RVs while we explore and clear the area for a more permanent spot for the RVs and potentially move again in the future. This lets us have a semi-mobile power station in an off-grid fashion and I’m very excited for it (We would be moving it maybe once a year as we clear further in)!
The setup description is basically an enclosed trailer with the solar system in it with a few panels on top/side. My understanding is that this is a floating ground situation, and my plan is fusing both sides on the battery/roof PV strings. There seems to be nonconsensus on whether to connect inverter ground to chassis, so I’m not sure about that but it seems at least somewhat safe either way. The tricky part for me comes in when we “park”. We will be setting up a semipermanent ground PV array near the location (That could be taken apart and moved to the next location, but is not located on the trailer). This will then be plugged in to the solar trailer to add PV capacity and beef up our input.
Here’s a basic picture. The full diagram is more complicated, but this should highlight the questions I have.
I would appreciate any input on the setup and how you would ground or fuse the system. I have specific questions too!
1) Should I just ground the solar PV array on the ground?
2) Should I ground solar equipment to chassis, then consider attaching to a ground rod to the chassis when we are parked semi-permanently?
3) Should I do something completely different, like grounding the DC negative to chassis and the solar equipment grounds, and leave the PV ground array ungrounded? Or ground to chassis only and ground the PV array? My understanding is that generally you only want one actual ground rod, but it confuses me that the solar array on the ground is more modular. Or maybe my fusing/breakers on the floating system is dumb, and I need to change that.
I really appreciate the insight and further questions! Happy to elaborate the setup if you need more information to weigh in.
