Nice. I suggest replacing your solar disconnect with one of
these. Do take care with the wiring. The solar panel negative wires must converge to a common negative when using these devices, otherwise they may not trip when they should. This is called a ground fault interrupt device and will completely disconnect solar arrays (positive and negative lines) in the event of a ground fault in the solar array; but, can also be manually ”opened” as a functional disconnect.
Hmmmm Never though of using that.
I was using the dual pole breaker just as a disconnect not an actual circuit breaker. Ill have to look more into this. Thanks for the tip.
Wow, this is exactly what I’m looking at doing for my application, and have been trying to piece together. What are you looking at for total cost on this setup?
I dont have everything yet.. But Ill try break it down for what my costs are.. I have been able to patiently wait and pick things up as they go on sale or buy from Kijiji / facebook market place or Amazon, or Alibaba. I also have a few of these things already in my trailer installed so I will be reusing them. So I didnt add in their cost.
Purchased so far:
Multiplus 24v 3000w = $1017CAD ( $810 USD)
Lynx Power in = $100 CAD ($80 usd)
8x 310ah Catl LiFePo4 Cells including all shipping and duty = $1170 CAD ( $938 USD)
JDB 100a 24v 8s BMS /w bluetooth module / shipping and duty paid = $75 CAD (60USD)
Need to buy: ( estimated cost based on local retail prices)
Mppt smart solar 100/50 = $400 CAD ($320 USD)
Smart Shunt 500a = $170 CAD ($136 USD)
Mega fuses total = $50 ($40 USD)
Buck converter = $39 CAD ( $32 USD)
Disconnect / gfi = $100? ( ??)
2x Qcells 400w Peak duo = $$500 CAD ( $400USD)
Already Owned from a previous small system solar install not accounted for:
Blue Sea Disconnect
Roof entry gland
Bundles of 8awg PV wire
Misc Large Gauge wires from 0/2 - 4 awg
crimp on lugs
MC4 connectors
All in all looks like Ill be sitting around $3500 CAD or approx $2800 USD not counting the stuff I had already. Which is about $500 above budget still, But I splurged on the multiplus when I found it so cheap.
Im hoping to be able to bring that total down a few hundred yet by waiting to buy a MPPT and smart shunt until on sale or such.
