CanadianEH
- Jan 25, 2021
- 71
Good afternoon fellow solar enthusiasts. I am new to the forum .. please go easy on me!
I am in the process of designing my ideal of grid Solar charger inverter system for my travel trailer. Any help and or guidance would be great. This isnt my first dive into the Solar pool, but I am no expert by any means. We also live in Alberta Canada which is a great solar potential area as we get ALOT of blue sky sunlight and the temperatures generally dont get extremely hot here.
The goal of the system is to allow my family more access to camp at sites and locations which do not have power hookups. My wife enjoys the outdoors as I do, but is a confessed "Glamper" she likes the niceties of home close at hand whenever possible. So far we have kept pretty well to camping at campground but limited ourselves to power only sites. This limits our availability as reservations fill up EXTREMELY fast around here. We have gone a few times using a friends Genny, but neither of us enjoy that. Even the quiet ones are too loud and annoying to turn on and off as required. We usually go for a 3-5 day maximum trip. But have taken a few 2 week hauls in the past. I did some basic calculations and added in about 20% for the unknown to be safe we would be around 3000wh a day. itll likely be MUCH lower. I would like to connect this to my current rv system to run all 110v plugs and the 12v items. as well as allow the 30amp power hook up the ability to charge the batteries when connected to power. ( im a little unsure about this part) The largest draw will likely be a Hair dryer, microwave or coffee maker..
Therefore.. rather than dumping $$ into a generator, I would like to install a system that would be available 24/7 with no noise and no campground restrictions on use ( ie only use between 8am and 9pm)
Here is my basic outline and thoughts on a system to suit the needs. Please feel free to let me know if you see any glaring errors in judgement or components.
Purchased: (from Shenzhen Basen currently enroute)
- 12 x 310ah CATL LiFeP04 cells. Will be used to make a 24v 310ah I ordered 4 extra cells incase of damage etc.. if all end up being good ill make another 12v 310ah battery and set it up for my dads trailer.
- Daly 8s 100a 24v smart BMS
- Daly 4s 100a 12v smart BMS
Ill likely have a buddy 3d print some nice cell holders if anyone has plans or ideas on this that would be great.
Had a friend give me a bunch of 8awg PV wire and mc4 connectors which he had left over.
Need to purchase:
- 2 x 400w Q-Cells Peak duo L-g7.2 Solar panels. ( connected in Parallel)
- Havent decided on flat vs manual tilting mounts yet.
- Victron 100/30 smart solar mppt
- Victron 500a Smart Shunt
- Wzrelb 2000 pure sine 24v inverter
- 24-12v converter
I am forgetting breakers, fuses, shut off switches etc.. as haven't got around to drawing this layout up yet.
Am I missing anything that I should have on that list, ie. for 2 panels in parallel do I need a combiner box?
Need to purchase:
- 24-12v converter
