Hi whoever is out there,
I have decided to put my toes in the water re DIY Solar systems down here in Melbourne Australia.
For better or worse I have ordered the components for an Eco-Worthy 2400W system, consisting of :
8*300W panels to be set up as 4 strings of 2 panels in series giving me 10a, 24V each
4*130AH batteries to be set up as 2 strings of 2 batteries in series giving me 24V system
1*60A controller
However this system does not come with a combiner Box!!!!!
I thought this would be a simple issue to fix, but am coming across many boxes that seem to have a 1440W limit.
They have 4 PV string inputs rated at 15A and a 63A circuit breaker, but still have 1400W limit??
eg the following
Can anyone explain this to me, as I cannot get any real answer from the suppliers??
1*60A controller
eg the following
VEVOR PV Combiner Box, 4 String with 15A Rated Current Fuse, 63A Circuit Breaker, Lightning Arreste Connector for On/Off Grid Solar Panel System, IP65
- This is in the specs:
- Extensive Application: The combiner box is a perfect device for outdoor installation and use. Suitable for photovoltaic on-grid/off-grid solar power generation systems, solar panel systems, PV array, RV solar power, home solar panel systems. It can support solar panel systems up to 720W in 12V system, 1440W in 24V system, 2880W in 48V system.
