If the two strings are the same voltage ie, same number of identical panels, the Voc of both will be comparable at all times so the array will tend to stick around the optimal point for both strings. If they aren't the same the controller will find the optimum point, with in the abilities of its MPPT algo, and sit there instead. That will be somewhere between the two string's Vmp.
