Just starting on my Victron ESS, 2 x 48/3000 multiplus II with 14.5kwh lifepo4 using EVE cells and a JBD BMS.
There is space to the right for another multiplus or possibly solar inverter, not sure yet.
The AC input will be coming from the existing house consumer unit that is in a cloak room across the hall behind that wall, the output will be fed to the consumer unit in the picture and some of the existing circuits will be wired into that. (For UPS function)
The OSB backboard is spaced off the wall using unistrut with rockwool insulation behind it in an attempt to reduce the noise from the inverters...
Any comments welcome
