BigBrosMo
- Feb 6, 2021
- 93
I am offgrid in Thailand. I have a new 280ah EVE LiFePo4 bank that I built with JK 8S BMS. I am here 3 to 6 months of the year and everything is packed up while I am away the other 9 to 6 months of the year (eg. the rainy season). Up until this year I have had Deepcycle Lead Acid cells and always kept the SCC running and charging while away. I've also packed up the 3000w pure sin inverter during this time.
This rainy season when I leave, my plan was to discharge the bank to 70%, disconnect the BMS so it doesn't drain the battery, and then store it inside the house (the store room where my SCC is can get quite hot)
However, now I think I want to install some IP cameras and motion activated lights while I am away so I will need to run a router, the cameras themselves and then of course the lights. Therefore I think I'll have to keep an inverter running. Here are my questions:
1. Should I run my main 3000w inverter 24/7 or would you install a cheaper 500w DC modified sin wave one? I don't think I need a pure sin wave one, and I don't want my big one to die, and think storing it is better than running it unattended for so long. If a cheaper one dies, I am not so bummed, and I could have someone replace it relatively easily for me.
2. Currently I charge my battery to 90% and then float it there as it's always under a small load during the day (I have a fridge etc). In the morning it's down to about 70%, then charges to 90% again, float, repeat. While I am away, with just router and camera, lights etc, usage will be minimal. Should I adjust my setup so the battery is charged to 90%, allowed to drain to 20%, and then allowed to charge again? Or am I better to keep it just as is always charging to 90% daily (maybe just disabling float)?
3. Since the solar shed gets quite hot while I am away (+40c I think), would it be beneficial to simply blow a fan on the battery box during the day? I know this isn't the most efficient but would it be useful at all for helping the life of the batteries?
4. What's the best way to monitor the JK BMS while away? It's Bluetooth - not WiFi
Appreciate all your thoughts.
