I want to know if the 405 watt bifacial panels are a good fit for the epever 20 amp controller at 24 volt. I know will said the panels can push 500 watts and the controller can handle that. Their under 11 amps so the controller can handle that. And thier around 50 volts the charger can handle 150/138@25°c. It can handle that. I know it has room for the 25%increase all across the board. So I know it can handle it. Now, it won't put out more amps than the panel is rated for will it, like if the voltage drops. I want to install up to 5 of these combinations together (5×1+1) but if the amperage is going to be greater than 10 amps per controller than it'll be too much. The battery recommended charge rate is 40 amps and max is 150amps. I was ain Ng for around 50 collectively and hoping for some losses in connection's. Is this functionable ? What arey possible max amperage outputs from my controller ? Thanks for anyone's knowledge.
