OK here goes...first post and new system.
Setup: Cargo conversion RV system
Problem: Batteries start with equal capacity (measured w meter). Balanced the batteries before initial install too, but overnight with minimal loads in the AM Growatt has shut down (cannot power back on) and left battery reads 1 volt!!! while other reads 13. This has happened both times I have done this test. I am happy to provide more info as needed to help w diagnosis. Only thing "plugged in" during latest test was powered cooler (this seems to run very efficiently).
Notes:
- Growatt 3000 24v
- 2 x 200 solar panels in series
- 2 x SOK 12V 100AH batteries
Notes:
- Growatt is set to user for battery type with 19,20, and 21 menu parameters set to Will Prouse suggested.
- Intended system use is for boon-docking with solar to charge system in day (supplemented with 2000w generator as needed) and power off batteries at night to run cpap machine, powered cooler, and a few 12 led's.
- Shunt monitor wires were disconnected as I thought that might be culprit
- I have not finished wiring 12v loads yet as you can see from pic (the wire bundle on left goes to loads nut hooked up yet.
- Will be installing victron 24/12v converter next week.
