justinm001
- Dec 18, 2022
- 1,579
Must have needed moon sandIn all of those studies they used the wrong sand.
Yep, that’s what I use.Must have needed moon sand
That's what they claim.It really holds heat that long?
Huh??With excess generation/ warming or overusing electricity, we might be contributing to the planet warming.
Solar with batteries is already in the single digits EROI. It's quite possible for excessive system size or short usage duration to drag that down near or below 1.How exactly does over consumption of solar generated electricity contribute to man-made global warming?
For now because it is the most cost effective way.Both of them are mined with diesel and manufactured with coal power.
I disagree with the premise but, so what?excessive system size or short usage duration to drag that down near or below 1
Could you sell it to the neighbor? If you have a neighbor.Hi, I’ve had solar for few years and have recently invested in a battery. I am on a feed in tariff (FIT) so sending power back to the grid is a bit of a waste to me, I get paid for what I generate, not what I send to grid.
My question is this - if I have used the majority of electric I need for the day and my battery is full, what can I use the remaining solar generation for rather than send it to the grid? I have been doing extra washing machine loads and dishwasher but am now at the point where everything is spotless.
Should I look to come off of the FIT tariff? This would be worse for me in the cooler months when I don’t export anything.
Is there something I can use at 800-1kw that could make me money?
Thanks for reading
Jon
I'm just laying out a logical case where a solar system could end up emitting more than not installing one.I disagree with the premise but, so what?
I don't know how you can spend more money and improve your ROI.
Idk where you are but the ground temp here in Ohio is 54 degrees all year round. Not sure how great of an insulator dirt or clay is.That's what they claim.
Of course it would depend on the size and insulating.
I'm going to use the earth to insulate.
I have a source of free sand.
My only expense would be the piping and heater. I'll know how well it works, in a few years.
Sounds a good plan. If you bury them at least 3000m deep, then your sand should remain at 100 degrees C minimum. The Earth has been doing a good job of insulating its heat over the last few million years. ?Of course it would depend on the size and insulating.
If you take a conservative usage (say 5MWh per annum) over 10 years, that would be 50MWh of electricity consumed from the grid. Assuming grid is 50% renewable (obviously varies, but about that for UK in summer), then to front load those emissions would assume that more than 25MWh of energy is consumed in the manufacture + distribution of 16 PV panels, an inverter and some bits of wire? I'd be surprised if it took that much to make them.I'm just laying out a logical case where a solar system could end up emitting more than not installing one.
If you would have spend 10 years in a home living on $20k of grid power, conservatively because it feels like a waste vs. $30k of solar equipment and enjoying tons of excess, it's not out of the question at all that the front loaded emissions that went into making the solar and battery products are higher than the running emissions of using the utility power.
I'm talking about with batteries. Grid tie comes with a lot more complicated assumptions when you're consuming fuel power at night and then netting it out with overproduction.in the manufacture + distribution of 16 PV panels, an inverter and some bits of wire?
About the same here in Kentucky.Idk where you are but the ground temp here in Ohio is 54 degrees all year round.
I'd say pretty good. Since it stays that temperature all year long. And isn't affected by summer and winter.Not sure how great of an insulator dirt or clay is.
Probably vertical wells.Although my house has a geothermal system and we've been trying to figure out where the water coils are in the yard/woods and can't. One winter I used a flir all over my yard and no noticable
Not for you or I or most of us. But there are people.
