quakershaker
- Mar 11, 2020
- 1
Hi all, hope someone can advise here. Here in the UK (London) I have 4kw solar with Solar Edge inverter (model SE3680H) and I want to build & connect my own battery storage to this system using LifePo4 batteries to store the excess solar production that I dont use during the day so i can power my home after sun has gone down. Has anyone done this previously with Solar Edge inverter ro know if it is possible/doable? I contacted a supplier and he advised against using a DIY battery:
"Dont even think about the DIY option. Especially not with SolarEdge.This is like mixing an Audi with a Renault Engine. Usually doesn't end well. In other words, it wont work. I know this from practice. SolarEdge Works with the 7kW and the 10kW High Voltage LG Resu Chem. If you looking for a cost effective option, try the AC Coupled Solis or (my preference) the AC Coupled Solax."
Any suggestions would be greatly appreciated before I go and buy some LifePo4 batteries from China!! Many thanks, Peter
