LordKitsuna
Hey everyone, I'm in the middle of rebuilding an rv and i ended up going with an Eg4 6000XP inverter. I'll have 3.6kW of panels however i was trying to find a way to "top off" when those aren't enough.
I found a supplier of ev charger cables that has a J1772 to NEMA 6-50 adapter and confirmed it works on random public ev chargers. Most will top at 30A at 240v output but some can go to 50A The only issue is you get no neutral from this, just an L1 L2 and ground. I can't find a definitive answer on if the Eg4 6k will accept line or genny input without a neutral.
If not what options are there out there for direct 48v chargers i could slap on the battery busbars that will run off 240 with no neutral?
