Justin Laureltec
Bay Marine Supply Tech Support Manager
The main thing I'd add to this conversation is just to point out that Valence U27-12XP batteries are not drop-ins; they have internal monitoring, yes, but no true BMS for HV/LV or hi/lo temperature cutouts... so always keep an eye on them, because they will not shut themselves down before any charge/discharge condition might kill them.
Only the U-Charge RT series batteries are drop-ins. Every other model, as expressly stated by Valence, "requires the Battery Management System", which of course is not available for retail purchase, thus the workarounds that people have developed.
I don't see any issues with the charge rates mentioned above, just keep a really close eye on everything until/unless you have your batteries connected to 3rd-party HV/LV cutouts and (ideally) temperature-sensitive cutouts as well. Otherwise, if that Epever ever decides to throw 16v at your batteries, or any number of other possible conditions, the batteries will be crisped rather quickly because they're not capable of shutting themselves down.
I do concur with the use of a 175A Anderson connector, though - those things are great and on my test bench I have consistently run way more than they're rated for through them without any issue... not that I recommend doing that.
