I just added two more batteries for a total of 6 in parallel. I now have 828 Ah with a projected usable of 662. The last two had less than 10 cycles each. It took a couple of days for everything to even out and show basically the same module, cell voltages and state of charge as the first 4.
I haven't discharged them very far as I'm again at the location with really crappy 15A service, however with the hybrid inverter I'm able to pretty much use what I want.
I have noticed that when bulk charging the cell spread often goes over the 10 mV set on the Valence software, this doesn't seem to trigger the cell balancing, I'm not sure what does trigger it. When discharging and the charger is at the end of the absorption cycle all cells are in the 2 to 5 mV spread range. Don't know if this is normal, can anyone with other LiFePo4 cells and the ability to log it confirm?
