Planning my solar setup for our TT and I have 2 Rich Solar 200w 12v panels on the way. Trying to decide if the 100/30 will be fine knowing that I will miss out on 3a of charging at low temp per the victron excel calculator. The panels will be flat mounted on top of the RV, so I doubt I will get the full 400w anyway. Planning to run them in parallel. Specs for the panels are:
TIA
- Maximum Power(Pmax): 200W
- Maximum Power Voltage(Vmp): 20.4V
- Maximum Power Current(Imp): 9.80A
- Open Circuit Voltage(Voc): 24.3V
- Short Circuit Current(Isc): 10.2A
- Maximum System Voltage(Vmax): 1000VDC
- Temperature Range: -40°C ~ 90°C
- Max Series Fuse Rating: 15A
- Weight: 26.5 lbs
- Dimensions: 58.7 x 26.8 x 1.4 in
TIA
