For any of you advanced Victron users out there, I’m trying to understand my options to control a Multiplus II on ESS modes 2 or 3 from my Modbus-RTU-based PLC.
From this document: https://www.victronenergy.com/live/ess:ess_mode_2_and_3?do=export_pdf
Dynamic control of Grid Power Setpoint - Modbus TCP Register 2700 in ESS Mode 2 is the simplest way to achieve the control I’m aiming for, so I’m trying to understand the easiest and cheapest way to do this from my PLC, ideally from Modbus RTU communication.
In particular, I’m trying to understand whether an MK3 can be used to control Grid Power Setpoint on a dynamic control loop (every ~5-10 seconds).
If it can, that should mean I could hook up a PC to change Grid Power Setpoint through it’s USB port whenever the PLC requests a change another USB port.
Or I could build an RPi-based VenusGX controller that could communicate with both my PLC through Modbus-RTU and with the Multiplus II through VE.Bus using an MK3 connected to it’s USB port.
But both of those are wasteful and I’d probably of just getting a Cerbo GX and having my PLC communucate with it through Modbus TCP.
So I’m first interested to understand whether any of you advanced Victron users knows whether:
PLC_Modbus_RTU -> USB -> MK3 -> VEBus might be a viable way to control Multiplus II registers from Modbus RTU communication?
And if not, second, if there is any easier / cheaper way to achieve this control loop using and MK3 adapter or other interface adapter from Modbus RTU or Modbus TCP over WiFi?
