I am planning two pairs of 3 x 12v 100w solar panels in series and then connecting them in parallel so a 3s2p solar array.
Am I correct in thinking that my Victron 100/50 solar controller will be able to handle this setup? I've estimated it should be around 72.9v at 10.4a going into the charge controller maxing out at 600w.
My solar panels are these: https://uk.renogy.com/renogy-100-watt-12-volt-monocrystalline-solar-panel-compact-design/
SPECIFICATIONS
Maximum Power at STC: 100W
Cell Efficiency: 22%
Optimum Operating Voltage (Vmp): 20.4V
Open-Circuit Voltage (Voc): 24.3V
Optimum Operating Current (Imp): 4.91A
Short-Circuit Current (Isc): 5.21A
Operating Temperature: -40°F to 176°F
Maximum Series Fuse Rating: 15A
Maximum System Voltage: 600V DC (UL)
I will be using 2 x LiFePo4 12v 100ah batteries in parallel.
Any help or advice is greatly appreciated. Thank you.
SPECIFICATIONS
