Hi everyone.
I have recently installed 2 x 435 Watt Trina solar panels on my self converted motorhome, with a micro inverter charger.
The inverter charger I bought states that it needs 90v minimum vac to 450v max vac to function. With the two panels I bought I'm averaging about 97vac, to my surprise it will not charge my battery bank. I contacted the manufacturer in China and they suggest that I need to have a minimum of 130 volts to make it stable and work whatever that means.
The problem is I don't have any more room for any panels, would anyone have a suggestion how I can potentially boost my panels to get that extra vcd. To be clear the panels are in series to create 24 volts I will post pictures and specifications.
Thanks
(Edit) :
As pointed out by others, The mppt tracking does say 30vdc - 400vdc wich I am well above.
I initially thought I need 90v min but that is "vac" on the stats for usage etc. Not applicable towards the issue.
Mr so called expert who commented earlier being a condescending A-hole didn't even pick that up tsk tsk!
Thanks
(Edit) :
