ahmed abdulnoor
- Aug 6, 2021
- 5
Hi.. i have 8 S ,280AH LFP bank with Daly 200A smart BMS and now it under test (no loading yet ); i set the high & low cutoff volts to 3.45 ; 3 V respectively ; balance starts at 3.4 V ; SOC sets for 100% ; my system has a balancer too . I noticed that the voltage is dropped ( after high volt cut-off ) from 3.45 V to about 3.3xx V appr. and when activate the bms again it starts charging till one cell hits 3.45 V ( charging current from solar controller is about 12 V app. and keep constant till cut-off ) then switched as usual but after a while the voltage of cells dropped again to 3.3xx V appr. .. even after changing the setting by rising the high cutoff volt to 3.55 V i got almost the same results or with few changes . I read about " absorption " but not quite sure if it's the cause or not and and Daly BMS has no such setting for absorption criteria or so and don't no why volts dropped though no loads applied . any help or explain will be appreciated .
