Hello again all,
Some might have seen my rants about my issue with the AIMS battery I bought last year. Its Only about 6 months old and it started to give me problems late last year. Last week it died completely. After several phone messages and an email asking for support without any response from AIMSCORP I’ve had enough. I disassembled my expensive AIMS Lifepo4 battery tonight. I’ll attach some pics too. I know I just ruined my warranty. But what good is it when the company won’t even respond to inquiries regarding tech support and warranties? Based upon that I would not purchase another one of their products.
What I found inside was interesting. The battery and BMS appear to be made of decent quality components. The assembly wasn’t sloppy. In fact it was better than what I’ve seen while watching some of Wills disassembly videos. Im not sure it measures up to the BattleBorn line.
I used a heat gun along the seams and softened them up then used a razor knife and my hand to roll the softened plastic up. I did this to three sides then once cooled I inserted a small flat bladed screwdriver and worked it along the edge until that happy sound of plastic popping loose was heard. Then I heated the last seam and folded the top back. The plastic is very compliant when it’s heated slightly. I think I’ll be able to use the top again when I replace the BMS.
The BMS is centered over the top of the cell frame providing for air circulation around it. It appears to be a good quality BMS but I could not find a name on it anywhere.
Perhaps someone could look at the pics and ID it. The wiring was of good size and quality too. I was impressed with the build of this battery.
Here’s the strange thing, as shown in the pics, upon opening the top I could smell a slight burnt smell. The BMS and batteries below the positive side terminals were covered in condensation. Looking at the BMS I could see some damage on the circuit board. I cannot figure out how the moisture got in there. Since I bought it I have never left it in direct rain or even left the battery uncovered outside the trailer. I’m perplexed by this bug. Maybe It leaked from around the positive terminal? I can’t tell at this time. Unfortunately there is enough moisture to damage the BMS board. I was able to pour out approximately 3-5CCs of moisture by tipping the battery on its side. There are several locations around the BMS where you can see electrical damage from what appears to be shorting due to the moisture. I checked the voltage of the battery cell assembly and it shows around 13 volts which I think is correct because it wasn’t fully charged after I got home from my last trip after New Years.
All in all it appears to be a decently made product but I have no idea how that moisture got in there. I’m hoping I can find a replacement BMS for it. Again, if any of you recognize this BMS please let me know where I can get one.
Thanks for reading.
Don.
Thanks for reading.
Don.
