BigIslandRyan
- Apr 16, 2020
- 35
Newb question; If I have 10 identical panels, each with open circuit voltage of 20volts. And I have a max 80volt all-in-one MPP inverter/controller.. what are my options for series/parralel of the panels? a series of 5 panels is too much voltage. A series of 4 is fine, and I can parallel two of those series, which is 8 panels. But what about the remaining two panels? Can I just run them in a series and "merge it" with the other 8 panels using Y connectors?
Can you do a 3S3P arrangement and still use the 10th panel? Idont understand how single panels can be added to the mix when they are at lower voltage? Can someone give me the simple explanation? I guess I'm asking about how do you join series when the series have different total voltage? Thanks.
