Jack Rabbit Off Grid
- Sep 6, 2021
- 477
So I have my Magnum 4448-PAE and mini Magnum panel connected to a sub panel. The sub panel I have double 60 amp breaker feeding each leg of my off grid house. The reason I used it at the was I because I had the double 60 just laying around.
In the pictures you will see the sub panel. The double 60’s run my house. The single 15’s run each receptacle that is connected to the bottom of it. Since the Magnum outputs 18.3 amps per leg should I switch the double 60 to a double 20amp?
Also I don’t understand why the Magnum main A/C out is a single 30 amp? the manual claims the unit is capable of 18.3 per leg 36.6 total.
