Wandererrr
In sticky situation because a lot popped up before completing a system that could work for the amount of power needed. I thought I had everything in order properly but I guess I went wrong somewhere and now I don't have the power needed for proper heating and the weathers getting cold.
Different people gave us different information but I did the best I could with what I started with, and what info I tried to diligently follow online.
I have 2 Renogy 100w 12v solar panels, 3 Renogy 12v 100ah lifepo4 batteries, a 3000w continuous 6000w surge Homkeep inverter, and a 30a Renogy charge controller.
The charge controller is connected to the batteries with #10 wires, and the batteries are connected to each other and the inverter with #2 wires.
But this setup isn't powerful enough to power 1500w devices that are necessary such as a space heater, electric burner, and air fryer/toaster oven.
So what do I need to get or change to survive in this skoolie? I've heard plenty of hate saying I shouldn't be doing any of this if I don't know what I'm doing, but I don't have a choice as I'm just trying to survive.
Should I get a Jackery solar generator with a portable solar panel, more solar panels and a new charge controller, more batteries? Something else?
What do I need to power a 1500w space heater up to 6hrs a day, in addition to using a 1500w electric burner up to an hour a day, and a 1500w air fryer/toaster oven up to an hour a day.
I don't want a generator because I don't want to use more gasoline and because of the noise, but if it's the only option then I will.
