hipringles
- Jan 31, 2021
- 214
I will be setting up 2x Growatt 5k's for a backup system. I plan to basically have a setup similar to David Poz does here, then connecting this subpanel to a lockout switch protected breaker on my main panel.
However both on David's video and a few others, people say the way this transformer is wired is dangerous in the case of a fault. What are the alternatives?
Additionally, using the transfer, what is the correct way to connect to the main? Is it just as obvious as connecting L1/L2 to the breaker, then the neutrals/ground like a normal generator hookup?
thanks!
thanks!
