What is the max reverse current of 'Victron Battery Protect'?
Redbud
Just Relax
Wisconsin
Can I send charger current in the reverse direction of a 65a Victron Battery Protect (VBP)?
I would like to have the charge and discharge current pass through the VBP. This is being used in a travel trailer where the cable used for loads and for charging, from the converter (charger), is the same cable.
The only alternative I see is a bypass switch around the VBP during charging. It would probably be pretty easy to wire a 60a diode across the VBP.
I don't know what the max charge current would be I would have to measure. The converter is a 35a. WF-8935 from WFCO Electronics.
Randy
