What size of Copper bus bar between Seplos batteries?
peterpan
Hi I Have 4 pcs of Seplos Mason that I would connect in parallel with tint copper bus bar like this
My inverter is the Deye 10kw inverter SUN-10k-SG04LP3 (middle in pic below) it draws 210a charge/discharge
Is it ok to connect 4 pcs of Seplos Mason batteries like the picture above and what size of copper bus bar do I need?
Link to Mason battery is
And where in EU do I buy the busbar?
the size will depend on the peak power your inverters will ask.
if you are into DIY, you could simply order 4* copper flatbars and drill holes.
otherwise , seplos does offer their busbar system
