Both of the links below from this post are useful.
Note: I'm sure CV is fine in >95% of cases when used with the AIOs on the market (presumably mostly used with EG4's old school quality tier), given the average IQ / sophistication level of a EG4 customer. I just want to understand why it's safe.
I'm trying to design a power backup system for my saltwater aquarium. In short, the system will be powered by a 12VDC power supply while the mains power is on. On power failure, the system will
electronics.stackexchange.com
No, it is generally
not safe to parallel two power supplies (even of the same model) unless they explicitly support such a mode of operation. Some power supply chips (such as the
LTM4625) are designed to be placed in parallel on the same circuit board. If configured correctly bench power supplies
can be connected in parallel for load-sharing.
