I have assembled a small setup 4S3P with 18650 li-ion batteries. They are connected to a MPPT tracker and a 40W solar panel. They feed small loads at around 50W max. in total. In order to do things properly I should have to add a BMS to each case of 4S batteries to keep them balanced but the cheap BMS's I bought do not really work properly, they should be advertised as space heaters instead.
I have fully charged all batteries one-by-one before adding them to the setup; they come from the same batch and are same age and use.
My question is, how often should I repeat this procedure to ensure the cells do not get too unbalanced?
I assume a bit of unbalance, even though not good for battery life, it should be tolerable.
