eel is NOT the seplos kit...Greetings from Belgium, I decided to go to I diy Eel - Seplos battery. With the Eve 305ah cells. 15kw for about 3000€.
Or you could contact docan or qso(both have EU warehouses) they all are selling rebadged seplos box..I contacted eel and they suggested me 51.2v 15Kwh EEL Server Rack LiFePO4 currently for 3079$ = ca 2850€. Not sure if the strange voltage could cause any compatibility issues? Or if there are any more hidden fees upon import to Italy..
Then I also saw this seemingly more standardized option that cought my interest for 4158€:
Kit SP24 Axpert Max 8.0Kw 48V Off-Grid Inverter and 2 x Pylontech US5000 9.6Kw
What do you think about these options? Any other ideas? Thank you!
Not sure what you mean by 'strange voltage'... 51.2V is standard for 16-cell LIFePO4 battery packs (i.e. 16 * 3.2V per cell). It is actually Pylontech that have the 'strange' (= cheapskate) configuration of only 15 cells (=48V).I contacted eel and they suggested me 51.2v 15Kwh EEL Server Rack LiFePO4 currently for 3079$ = ca 2850€. Not sure if the strange voltage could cause any compatibility issues? Or if there are any more hidden fees upon import to Italy..
I don't think a BMS would be a reason to have one less cell, since there are 16S BMSs. Is the Pylontech a different chemistry than LFP?- Pylontech seems to have a built in BMS? Mb thats why they have 1 cell less?
All battery rack systems will have a BMS, nothing to do with 1 cell less.- Pylontech seems to have a built in BMS? Mb thats why they have 1 cell less?
- If buying the EVE cells I guess I should add a BMS as well and consider it for the cost?
I was actually thinking of their battery rack...Then there is also the full kit for 280Ah
SEPLOS Mason Kit and x16 Grade A EVE LF280K Battery Bundle (15% discount) ca 2800€/14.336 kW (£2,396.00) => 0.1953€/Wh
So with the discount this kit seems like a really good deal on par with the options above!
