Which battery’s for daily use
Bozzydogg02
Saltash, Cornwall
Hi,
I’m finally adding new battery’s to my system (5 x 100w solar panels in series with photonic universe 150 v solar controller) and having wasted quite a lot of money last time buying batteries that weren’t fit for the job I’m hoping to get some expert advice on what to go for this time.
My options are between:
victron gel agm 90 ah x 2
Or
Victron VRLA agm 110 ah x 2
We have a:
5 v usb port
2 x 5 v lights
I’m going to be adding:
250 w victron inverter (ditching the 4000w one we currently have)
12 v cigarette charging port
Diesel heater
400 w wind turbine
Please excuse my lack of knowledge, I hope there’s enough info to help form opinions.
Thanks
What is your load or what are you planning to run?
I would go with at least 200Ah and maybe 300Ah with 500 watts of solar but depends on how you are using it.
Your the first I’ve heard of actually buying a Victron battery.
Some more research may be in order.
The inverter for a couple of hours, lights for up to 12 hours (probably more like 6 but always over estimate) usb for carging phones 6 hours and to start up the diesel heater 6 times per day (I have no idea on how much the heater uses to get started sorry)
I should have also mentioned I’m going to be getting a generator in a few weeks and charging the batteries once or twice a week using that with a victron smart charger.
The main thing is working out weather I should be getting the gel for the deeper discharge ability or the vrla for the extra Ah?
Just out of curiosity, how did your options get narrowed down to these 2 batteries?
This one?
To be honest I just seen victron as a trusted brand, others that I have spoken to have told me it’s about the best off grid stuff you can buy. But I guess that’s why I’m here to find out from the experts!
Yes that’s the solar controller ?
"How much power does a diesel heater use?
The heater's power use will depend on its size, but generally, diesel heaters will use 8 to 12 amps during start-up, with some models then requiring as little as 0.5 amps to run continuously, and an average of 1-2 amps."
That isn't much load at all so you should be fine with 200Ah of capacity.
I haven't used Victron batteries but I had 125 AH Vmax on my system and lasted for 10 years. Recently replaced with one LFP.
Amazing, thanks so much for your help!
This Victron data sheet shows three battery types: AGM and Gel "Deep cycle" and "Gel Long Life". The Deep Cycle batteries only last 500-700 cycles at 50% depth of discharge. That's less than two years of daily cycling. The Gel Long Life lasts 2500 cycles at 50% DoD and would be more appropriate for daily cycling.
LFP is typically rated for 3000-8000 cycles at 80-90% DoD. That's probably the more economic choice for daily cycling.
The Victron equipment is top tier. But the Victron batteries I’ve looked at (LiFePO4) were way overpriced.
I think it’s fair to say there are many other high quality battery brands that are a much better value proposition.
I’d look at SOK if you want a top notch battery. I anticipate 10 years of service if not stored very hot or charged when freezing.
Thanks for the advice! I had a quick look at SOK and I don’t think theyre available in the UK and way out of my price range if I’m trying to get around 200ah. Again, thanks for your help and advice!
Will Prowse has lots of reviews of cheaper alternatives to SOK that are significantly cheaper and some reputed to be very good. Might be worth a look at his recent videos.
Curious how you are going to those panels to work with no sun? (kidding). Welcome to the forum.
In my head, Victron AGMs would be a shocking waste of money. I would spend my money ensuring a robust charging system ro ensure whatever batteries i was using were charged to float everyday. Expensive batteries are destroyed just as easily as cheap ones by an inadequate charging setup
Remember, in your purchasing calculations, lead batteries you have to cut their available AH in half.
So, if you NEED 200Ah of available current, you have to buy 400Ah of battery.
With LFP, if you NEED 200Ah, you only need to buy 250Ah.
The different battery chemistries have different discharge curves and life cycles of use.
I’m adding a 400 w wind turbine this weekend, and looking into getting a generator and a 230 v smart charger in the next few weeks (once I’ve saved up again).
Would you say I’d be better off getting cheaper batteries and using the money I’ve saved from that to get a smart charger and old second hand generator?
See picture for wind turbine specs.
These are the products I’m thinking about if I was to not go for the victron battery’s:
I plan to run the smart charger off any old inverter generator I can get my hands on (father in-law has a decent one I can lend but would rather get a cheap old one second hand one) IMG_2123.jpeg
I would max out solar. My 920w of solar cost a fraction of the price of my 1.1m turbine. Forget what it says on the side of the wind turbine. You will only see 400w in a gale. Most of the time you will be lucky to see 100w. I will not be fitting another wind turbine. Mine is old and when it breaks, it will be removed for good.
We are out in the Caribbean. We used to see a lot of wind turbines but not any more. They are too much hassle. Noisy, never trouble free and expensive. Solar has replaced them and so many people now use lithium batteries that you dont need a wind turbine.
I have no more room on my roof for solar and to add any more would mean a new solar controller as mine is maxed out on what it can handle. Also we’re in the uk so not as fortunate as the Caribbean for sun hahah. I’m just putting alternatives in place for the winter as the uk doesn’t see much sun at all during the winter, during the spring/summer the solar panels I have are more than enough to keep us fully charged. I know that the wind turbine is not going to produce 400 w, probably about 20% of that but it’s better than nothing while the sun isn’t shining.
Also the generator will surely do a job a couple of times a week?
So as for my original question, would you get cheaper batteries (the ones I shared) and invest in a generator and charger or stick to the more expensive trusted ones and wait a few weeks to get a generator and charger?
I can’t afford lithium batteries, it’s just not an option at the moment, maybe in the future but I need something in place for the coming weeks.
as youre in the UK have a look at Fogstar batteries www.fogstar.co.uk -
i have a 300ah (£800) in my motorhome and a self assembled 14,3kw home storage battery (around £2400) at home (Essex UK) - very pleased woth their performance
There were some cheap vehicle batteries for sale on ebay the other day, which had been tested and were suitable for home storage systems from what i could see ..
and i wouldnt bother with the wind turbine, invest more in your batteries. even more so if you can get a cheap charging rate from one of the power suppliers, so you can charge during off peak and use it at standard rate. i do that and am paying @15p per kw at low rate then using that power when the rate is 36p ! so virtually getting half price electricity
Thanks for your help but my budget is £570 hence opting for agms, as I also need to include an inverter in this price, just trying to get the best bang for my buck, we hardly use any power just the battered old lead battery we are currently making do with is dead by 8 - 10 pm and then we’re onto candle light
