I want to install 2 panels on my motor home and I'm having a little knowledge problem in picking the correct charge controller. I'm not sure if my calc's are correct?
Panels: (2) REC370TP25M72 Mono Panels (Spec Sheet PDF)
Wire gauge: My run (panel to controller) is approx 20 feet. 6 Gauge??
Batteries: Manual switch between (2) 12Vdc 70AH Lithium-ion (Old Spec Sheet - now 70AH) in parallel and (1) 12Vdc 110AH AGM (high amp use audio battery)
The 2 Lithium's will be used the run my motor home 120Vac refrigerator (through a 2000W pure sine inverter) and the Gel will be a backup.
Fridge has a 15A circuit requirement and a 528kw / Year Energy rating so ......... (528,000W ÷ 365 Days) ÷ 24 Hours = 61.42W/H ÷ 120v = 0.52 A/H average. Adding 5% loss @ pure sine Inverter and a 10% factor for start ups = 0.6 A/H. One of my panels would probably be adequate, but I'm looking at expanding the draw to use on counter top appliances for the motor home through a separate inverter.
My existing house batteries will continue to run independent of the solar battery system.
Here's what I'm getting for charge controller requirements:
ELECTRICAL DATA @ STC
Nominal Power - Pmpp (Wp) = 370
Nominal Power Voltage - Vmpp (V) = 39.8
Nominal Power Current - Impp (A) = 9.3
Open Circuit Voltage - Voc (V) = 47
Short Circuit Current - Isc (A) = 10.2
ELECTRICAL DATA @ NMOT
Nominal Power - Pmpp = 276W
Nominal Power Voltage - Vmpp (V) = 37.1
Nominal Power Current - Impp (A) = 7.44
Open Circuit Voltage - Voc (V) = 43.7
Short Circuit Current - Isc (A) = 8.02
I'm traveling so I used a Volt Correction Factor (VCF) of: 13 to 5 degree Fahrenheit ambient = 1.16 VCF
Using 2 panels in series:
47 Voc X 1.16 VCF X 2 = 109.4 V
10.2 Isc A X 1.25 (safety factor) X 1 string = 12.75 A
Panel watt conversion: [740 W ÷ 47V] X 1.25 (safety factor) X 1.16 VCF = 22.83 A
Use: 30amp 150v MPPT Controller
Using 2 panels in parallel:
47 Voc X 1.16 (VCF) = 54.52 V
10.2 Isc A X 1.25 (safety factor) X 2 = 25.5 A
Panel watt conversion: [370 W ÷ 47V] X 1.25 (safety factor) X 1.16 VCF X 2 = 26.88 A
Use: 30amp 100v MPPT Controller
Questions:
1. Do I use 'STC' or 'NMOT' data? I used worst case STC. I'd rather save the money if I can use NMOT data.
2. Are my calc's correct?
3. Is my wire gauge too big too small?
Questions:
