If your charge controller, or inverter can handle the voltage, then do series. You're wallet will thank you because of the cabling cost, and no need for combiners, or branch connectors.
This will give you a Voc of 108 V, so you'll need to find a charge controller that can handle that. How much are you willing to spend? Victron makes this number of models that can handle 150V :
Get the highest attainable efficiency from sunlight, even if it is limited, with the solar charge controllers from Victron Energy. Find a dealer nearby.
