I have 14 100 w panels that have voc of 24.5 and isc of 4.5. I know I should run the volts high as the unit requires 90voc to run. I can safely run two strings parallel and stay under the max amps of 12. Does it matter if I run all 14 in series or should I run 2 parallel strings of 7 panels in series?
