How are YOU doing it?You can do it with as little as smart relays, as long as you have enough steps to work with. Ideal way is a static controller that is continuously variable, but I doubt anybody is doing that DIY at home.
Sweet! Where are you located? So no pumps at all for the thermal system?I have 12.8KW of PV (off-grid) and solar thermal for hot water (Chromagen 50 gallon - thermosyphon). I'm very happy with the system.
I'm in Belize.Sweet! Where are you located? So no pumps at all for the thermal system?
Wow that's sweet. With a single panel what type of high temps do you see?I'm in Belize.
No pumps. Its a single 4x7ft panel. The tank has a 2500W 220V element which operates on a timer switch & thermal switch. So twice a day (evening and early morning), it has the opportunity to come on for an hour and heat if the temp is less than 120F, it works great!
There is a pressure release valve which regulates the max temp to around 135F, even on mildly sunny days it has no problem maxing out. My timer is set to come on at 4pm, but we've only seen the electrical element come on once at that time after 2 overcast days. It comes on 9 of 10 days from 4-5am. It seems the 1 of 10 days it doesn't come on in the morning is when we use less hot water at night (when a family member or two skip a night time shower, preferring to shower in the morning).Wow that's sweet. With a single panel what type of high temps do you see?
Our system gets up to ~160F, which gives good ride-through, although extra insulation would be good. The mixing valve gives us consistent temperature at points of use.There is a pressure release valve which regulates the max temp to around 135F, even on mildly sunny days it has no problem maxing out.
Pv is not that cheap lol. I think professionally installed thermal is just too bloody expensive
in 2007 ...
However, the system has been trouble free all these years. Do PV inverters last this long?
Is there a guide for this?With a few cheap panels, a cheap water heater , and a DC relay. You can have hot water for under $1k.
And almost zero maintenance.
Pet peeve, but it is $0.07-0.08/kWh for 4-4.5 average hours of (rated) sun once you take in time value of money, losses, and tax rebates.PV panels new are now $0.50 to $1.00/W. Used, $0.10 to $0.50
Grid-tied PV hardware (DIY labor) is around $1.00/W (at least if no RSD required). That works out to $0.025/kWh over 20 years.
I'm sure that somewhere there is.Is there a guide for this?
$1,500/kWh(PV) - 30% Tax credit = $1,050 PVCan you present your calculation?
Last time I worked it out, interest rates were like 0.05%, so time had no value.
Perhaps coincidence, but both rates and price of PV has risen recently.
Of course I agree with this; I only point out the "technical" price because when people expect savings from an investment it is important to have those expectations work out.Other point of view is payback or break even compared to utility rates, which can be quite short for those of us paying $0.25 to $0.50/kWh.
Interesting idea. You could use some of those pex aluminum heat spreaders that is used for radiant flooring.I actually thought about adding pex tubing loops under my panels for this reason. Pulling the heat away from the panels would also make them more efficient. Plus it could be used to melt snow in the winter.
well you should thank him for watering your lawn for free.My neighbor has a massive system and experienced a leak a few months ago. Sounded like a waterfall and it drained his pool. Flowed into my yard and many others. No thank you. Many other neighbors here in Vegas have leaks with their system as well.
Then I tried ac and dc elements. Again not happy with it since I couldn't tell it really helped any.
Back in the day when someone said "DC heating element" for a hot water heater they were referring to low wattage elements.This doesn't make much sense, a heating element it just a resistance - there's no AC and DC elements. You do however need an MPPT controller otherwise you'll just be loading the panels with a fixed resistance.
How do you come about the $1500/kWh?$1,500/kWh(PV) - 30% Tax credit = $1,050 PV
IRR = 6%
FV = 0
n = 240 months
-------- (fancy calculator step)
PMT = $7.52/month/kWh
$7.52 / 30d / 4.5h = $0.055/kWh (PV)
$0.055 / 0.85 AC/DC Ratio = $0.065/kWh AC
I originally took additional 10% losses on top of that, but I forgot that we weren't talking about a battery system. At 7% IRR it works out to $0.07/kWh AC.
