Matty-Lee
- Jan 21, 2021
- 49
I have had my battery up and running for less than a year now. It's connected to the solar charging system in my van which I use for occasional for weekend trips away.
When the van isn't being used which is most of the time the whole of the charging system is disconnected and the battery is just left to keep a tracker powered via USB.
I was out in the van at the weekend and on the final day the power failed completely. Fortunately I was able to get it all working by taking the BMS out.
I'm surprised that it has failed as the demand on the system is small so I'm wondering why it decided to fail and whether it is actually worth me replacing with another?
There doesn't seem to be any obvious damage on the outside of the unit.
Do you think it is worth me undoing those screws and taking a look inside?
Admittedly the BMS was never mounted with great airflow but there is a charge controller temperature sensor in there and it never gets that hot in the box.
It was a mild winter's day here in the UK when it broke and the temperature in the box was about 8 degrees Celsius.
That's it, squeezed in at the bottom (disconnected).
Any ideas? I know some people don't bother with a BMS so it it worth me spending out on another?
Thanks,
Matt
Thanks,
Matt
