Is there some property of AC that makes grounding more necessary or more effective? Or is it simply that AC is more of a danger as it tends to be higher voltage and/or more adept at screwing with the heart?
DC is generally lower voltage .... and therefore not as dangerous. If you get into higher voltage DC, however, it is more dangerous than the same AC voltage.
If you grab high voltage AC with your hand it will throw you off .... If you grab DC, it will cause your muscle to clench and you may not be able to let go. I don't know what the grounding rules are for higher voltage DC.
it also does not hurt to ground anyways, alls it takes is some water and you touch it, if you notice all the UL controllers, inverters are grounded.
maybe for lightening and or for getting shocked. better safe than sorry.
Why do DC systems not make use of grounding to the same extent as with AC
The problem is first terminology: in AC systems 'ground' is meant to be earth, with neutral the return path (I'm European, keep your split phase nonsense) . In DC systems, 'ground' is meant to be the 0V reference potential, for example the chassis of a car is 'ground' there. That's why we tend to speak about 'earthing' when we talk about the wiring that usually does not carry any current in normal operation and is there for safety.
Can you elaborate on what this means, how its determined?
DC 'ground'/negative/black wire is conceptually similar to the AC neutral/white wire, is it not?
in a sense ground is just a backup neutral is it not?
intended to protect living things, not to protect the system itself or prevent fire or damage?
Two entirely different types of electricity that have very little in common other than moving electrons.
This is an argument every single time when AC & DC guys meet on forums...
Virtually noting in common between AC & DC other than electrons and materials that will conduct/transmit electrons.
AC has a FREQUENCY (Like radio signals) and is 'Transmitted'.
Now, you can't explain this to the AC guys, but there is a reason AC wires are called 'Transmission Lines', the guys that did have it figured out named it correctly, and they haven't got around to screwing with it... Yet...
AC IS ACTIVELY SEEKING A 'GROUND', like a radio signal is seeking something to act upon, like an antenna, or the food in a microwave.
AC will 'Leak' (path of least resistance) to moist air, it casts ions out looking for ANYWHERE with lower electrical potential to 'Ground'.
It does NOT seek a direct path back to 'Source', it 'Seeks' ANY lower potential conductor, and 'Ground' is handy way to dispose of escaped current safely, so it's widely used to dispatch the electrical potential power rather than knocking the snot out of YOU...
You being conductive and lower electrical potential, you don't have to be 'Grounded' to get the snot knocked loose.
DC 'Seeks' to complete the circuit back to 'Source', and DC is CONDUCTED (not 'Transmitted').
Since DC seeks it's polar opposite, 'Earth Ground' is virtually useless as a 'Safety'.
Unless you are the circuit completion, as in have one hand on the negative and the other on positive, you DON'T get the snot knocked out of you, DC isn't 'Seeking' earth ground or lower potential, just it's polar opposite.
(Every 'Electrical Engineer Type just hit the ceiling, head exploding...
Since the core differences aren't taught in 'Engineering School' this always drives the EE types up the wall since they have never heard it before)
Not exactly the question you asked, but maybe should have asked?...
DC is directly the electro-magnetic link, a force of nature, or a force of the universe, like gravity,
OR,
It's a chemical reaction (Batteries), and again, a force of nature or a force of the universe.
DC happens all the time, everywhere, like in every nerve impulse in your body or the constant positive/negative charges in the atmosphere.
Always one polar opposite seeking connection back to 'Source', a DC Circuit being completed.
From a nerve impulse you never think about but happens a billion times a second in your body, to lightening strikes, it's all a force of nature and polar opposites seeking to complete the circuit.
Nature doesn't produce 'AC',
AC is entirely man made and it's unstable, seeking ANY conductor with lower potential.
You can't store AC power, it's generated and used immediately or lost.
There is no such thing as a chemical AC reaction, so no such thing as an AC battery.
The mixed terminology perturbs me, as it muddies the waters, and makes an already confusing topic somewhat more confusing. I'm not informed enough to know if there is a reason the terminology is thus, but it seems less than ideal.
I try to avoid the term ground when talking about the DC negative wire (maybe this is misguided).
I may be misunderstanding something, but it seems like the DC 'ground'/negative/black wire is conceptually similar to the AC neutral/white wire, is it not?
And that ground or earth is a safety feature that provides an alternate route back to the source (earth or ground in most but not all cases). Maybe its an oversimplification but in a sense ground is just a backup neutral is it not?
One more unrelated/semi-related question. Would it be correct to say that grounding/earthing in the AC sense of the term (unlike fusing) is a safety feature intended to protect living things, not to protect the system itself or prevent fire or damage?Two different sciences, two different disciplines in application, two different educations, two different vocabularies...
The guy that mixes terminology is usually a beginner, so you steer him towards corrections.
DC never has had, and never will have a 'Ground' or 'Earth Ground'.
AC electrical engineers hung 'Chassis Ground' on vehicles a long time ago, which got shortened to 'Ground'.
The absolutely correct term is Negative Circuit Path in DC wiring.
All DC wiring has just two 'Paths', the 'Positive' conductor, or the 'Negative' conductor.
(DC is 'Conducted', not 'Transmitted' like AC is)
The 'Chassis Ground' was the metal body or frame, steel is a HORRIBLE conductor of electricity (compared to silver, copper, brass, bronze, gold, ect.).
Steel is actually an electrical 'Resistor' if you want to get down to conductivity scale references...
Nope.
AC is transmitted, and it's seeking ANY lower potential conductor, 'Earth Ground' is that lower potential (zero volts) conductor that is the path of least resistance, so it's used primarily as a 'Safety' to shunt AC safely away.
DC is Conducted, and seeks ONLY the polar opposite.
You have to be touching BOTH the 'Positive' pole, and the 'Negative' pole to get shocked.
If it's a completed circuit, it's safe for you to touch since the path of least resistance is the closed circuit and NOT you.
Touching low powered DC circuit anywhere is only ONE connection point, you are not connected to the polar opposite, so you don't get zapped...
Think of it this way,
Hundreds of AMPS in a car battery, Thousands of times what it takes to stop your heart.
All that connected directly to every metal part of the vehicle... Yet the vehicle is dead safe to touch anywhere without getting zapped or killed, and since it's on rubber tires, exactly Zero parts of that vehicle are 'Grounded' in any way.
You can have a million volt AC line drop on the car, and as long as you don't step out and make the earth ground connection, you won't get cooked...
FUNDAMENTAL DIFFERENCE in the way AC works compared to DC, touch ANY AC line with 1,000 amps and you get cooked like a hotdog.
Any crossing of technical terms between AC & DC are laymen produced, or AC guys that don't understand DC.
If I were to attempt to distill this down to one simple distinction that I can wrap my head around, would it be correct to say that DC wants to return to its source, AC wants to go anywhere with lower electrical potential (i.e. lower voltage), and both will preference the path of least resistance?
If its not too broad a question, what are the practical implications of this distinction?
I can have a 5V AC source capable of delivering hundreds of AMPS as well and touch that without issue, even holding both wires. You need a combination of both volts and the capability to deliver the amps to cause harm.
