My off grid system produces a max of 142 volts. It is being fed into a Victron 250/85. The closest SPD is 300 volts.
All indications are that if I feed more than 250 volts to the SCC, such as by over paneling, I will destroy it.
If that is the case, then will the SCC be destroyed by surge voltage over 250v volts, before the SPD clamps it at 300 volts?
In the case of a nearby lightning strike causing a major surge, the SPD should protect most of my equipment, though I will probably lose the SCC. Is that correct?
Or does the SCC allow a surge, just not continuous voltage ? If so, where can I find those numbers?
