The system has been through 3 Summers now, and I have modified it each Winter, based on what I learned each season.
Very cloudy here (tropical) Summers, PV performance suffers dramatically.
Have added more PV each Winter, w/ associated electronics.
Summer of 2023 demonstrated the need for more PV....again.....
Looks like I can "over panel" the Schneider MPPT 100A 600vdc charge controllers quite a bit,
as long as the "Max array short circuit current at ST" is observed, (35A),
as well as the 195-510vdc MPPT voltage range.
diysolarforum.com/resources/overview-of-over-paneling-an-mppt-controller.229/
Here is what might work for this Winter project:
Replace the 16 REC ALPHA 365AA with 16 SILFAB SIL-490 HN.
That upgrade will provide 2kw more PV capacity.
Ground mount, so not a big ordeal to swap panels.
The SILFAB 490's are enormous. 89" (2263mm) long!!!!
So I will have to extend the ends of the ground mount frame by more than
7' (214cm).
The Voc will increase from about 350vdc to about 432vdc.
(Not concerned about Winter temperature effects on Voc here.)
Current increases from 10.26 to 11.53.
Afterwards, there will be a pile'o 16 spare REC365AA to use for Winter 24-25, if needed.
Best part is that the SILFAB panels are local pickup (https://www.gexpro.com/), no shipping $$$ or anxiety!
There is just enough room in my van, the SILFAB's are 14" longer than the LG LG425QAK-A6 (425W) panels I picked up last year for the shed roof mount project.
7' (214cm).
