I posted this on the BMS page as well, but this could be more battery than BMS. Sorry for the duplication!
Need some guidance for my battery build. I have a 4S 12V LiFePo4 battery and installing the JBD 4S 200A BMS. The battery is 280ah cells. My question is what size wire should I attach too the tabs on the BMS that connect to the battery for B- and to the battery box connector for the load on C-? The distance is about 8” from the BMS tab to the battery connection and about the same from the other BMS tab to the battery box connection. I have been looking at wire size charts to get the answer and saw everything from 2 AWG to 2/0 AWG.
I am building 2 batteries that I will connect in parallel and the heaviest load in the RV is the 2000 PSW inverter.
Thanks in advance for the advice.
