Ok I'm almost there. I think my confusion is from watching Will and seeing his PV cables run into a breaker and then seeing a different cable from the breaker/disconnect to the inverter. What is this cable?The two strings will be separate runs back to the inverter, a separate red and black for each sting. There are 2 PV inputs on your inverter each string will connect to each of the inputs
