Technically you were. Your approach would have made the panel 2 feet away with notably longer cables to meet your criteria.
LOL... I've definitely given you enough to draw your own conclusion. You could have 2 feet on one end and 500 feet on the other, and the only issue is you'd lose power in heating the extra wire by an amount you couldn't detect, and you'd lose a LOT of power if they were the same gauge.
Wire is selected based on:
1) current - a minimum wire gauge is needed for any given current.
2) voltage drop - larger than 1) might be required if the voltage drop results in excessive loss.
Risk is presented when 1) isn't followed.
The best (and pretty much only) way to "blow up" your system in this context is to exceed the voltage of your charge controller with your array Voc in cold conditions.
