@Steve_S
Bummer! Guess I was lucky with my ShunBin battery box. It's been working well aside from the capacity issue. Yep, you're right, the price is much better with Xuba. Also, I opted to go with your Samlex 4000W Inverter/ charger recommendation and used it for several weeks at home with the ShunBin battery box before setting them up at my recreational camp a couple hundred miles away. I bought the Xuba cells and another Samlex 4000W inverter/charger for here at home (planning for hurricane season). It's scheduled for delivery tomorrow.
I'm exploring the Dark Side, ha ha. I had issues yesterday with a new 100A BMS w/ bluetooth Will had recommended. Ended up using a Daly 200A BMS I had so I could do the initial capacity test. I have the Opto 22 Solid State Relay I wanna test with the Samlex relay switch once it arrives. I also received 2 really cheap 15A BMS's. I wanna see if I could really get away with using it to balance the 14 KW Xuma cells with the Samlex 4000W inverter.
~ snipped image ~
Guess I got lucky with no additional shipping fees (DDP):
From Amy at the time I placed my order (Fri 6 Mar):
1. Air Freight - $799 - Tax included, arrive at home, arrive in about 10 working days
2. Sea transportation - $551 - Tax included, arrive at the door, arrive in about 30 days
Sea is $248 cheaper, but I didn't want to wait a whole month plus any potential coronavirus delays on top of that.
Low voltage balancing differences. I've seen this with the 8 50Ah cells I have for tinkering. My understanding is the top 10% and bottom 10% tend to be less stable balancing-wise. Hence, why it's usually recommended to use the middle 80%.
