I look at this as a new project with challenges. I have learned so much just by reading the forums and now I am actually applying what I have learned. And as we have both found out the learning process is continuous. I also enjoy passing on what I have learned. All of this gives me something to do to pass the time.
I am all for parallel top balancing. There are different ways of doing it but I feel it should be done with these bigger cells. If they were matched when they left the factory then it would be a different story. But I feel once it's done, it's done and it's time to put the cells in series and run them through a few cycles for testing. Not just to test capacity, but testing all connections are good and so on.
Most people stay between the knees and if a cell drifts outside of the knees that cell can be corrected without taking the pack apart by using a resistor or charging independently to better match the other cells. If the cells gets to far out of hand then one can add active balancing. For what I paid for the cells, if I get around 95% capacity from the pack I will be happy.
